Continuous effective capacity 50 W × 6 ch (4 Ω) 200 W × 3 ch (4 Ω, MONO)
Input sensitivity · Impedance NORMAL(LOW):0.5V/20kΩ (HIGH):2.0V/3.1kΩ DIRECT:0.5V/25kΩ
S/N ratio (fixed output) 105 dB or more
Full high-profile wave rate: Below 0.005% (4Ω, 1kHz, DIRECT) Below 0.008 (4Ω, 20~20,000Hz DIRECT)
Dumping factor More than 100 (4Ω, 1kHz, DIRECT)
Consumption power 27.6 W (2.3 A , no signal) 552 W (46.0 A, 4 Ω, rated output)
External dimensions 670 (width) × 302 (depth) × 76 (height) mm Weight: 12.6 kg (body)
- Indice forum Componenti HOT ZONE "Mettiamoli a nudo" AMPLIFICATORI L LUXMAN
- Oggi è 10 mag 2024, 12:37
Luxman CM-6000
Luxman CM-6000
